As above people , i am getting some vibes through the steering wheel and pedals when the car is idling , it doesn`t matter what position the gearbox is in. The car is a 2013 model with 64k miles.
I have had a look around underneath and there is nothing obvious to report and am edging towards the motor mounts as the source of the problem.
So , can they be replaced without dropping the complete engine / gearbox / subframe from the car ?
The mounts are the ones with the vacuum fitting  on the lower part of the mounts.
Cheers - K
