A little background to start. I've never had a problem with this before and I've had 2 other alignments. I recently did some more suspension work (adjustable lower control/coffin arms in order to get my negative camber within spec) so brought it in again for an alignment. They had a bit of difficulty getting everything within spec as several parameters are interactive. In any case they got it close, but the steering wheel wasn't centered. Instead of adjusting the tie rod ends, I think they just popped the steering wheel off and moved it a few splines. Would this mess up the steering angle sensor so it would have to be re-calibrated?  Also, I have Durametric which has a re-calibration command, but I haven't been able to get it to work yet. I reached out to Durametric and they swear the function works, so either I'm not doing it correctly or my steering angle sensor is bad...
Edited by dporto
