Hi Guys, can anyone advise / comment on whether (and where) a '97 Boxster base might have a power steering fluid filter? BMW has a filter (albeit simple mesh) in the reservoir... does Porsche do the same? Also, anyone installed an in-line PS filter (good quality on return line)? I looked hard through the topics / articles but may have missed it discussed previously 😕
There is no ps fluid filter in a 986. I have not heard anyone installing a filter either.
I’ve done a PS fluid flush by disconnecting the return line underneath the driver side of the car  and there is a wire cage.
By far, the larger issue with the power steering systems on these cars is heat, not debris.  More power steering pumps fail from overheating than anything else.  There are a couple of aftermarket companies producing add on coolers because of this issue.
Thanks Gents for the replies. I've just done what you've done, Duster. Only got 500ml fluid out then filled up. Will drive for a bit and repeat with remaining new 500ml still in container.
JFP, good point. After reading your comment I looked under my 986 and keeping an eye on the PS hose closer to the exhaust headers... not bad but looks like heat is affecting it. I do know you're referring to the heat generated by the PS system though.
Both replies good to know.
