I had my tires and sensors (to Hufs) replaced a few months back, everything was good until about a months ago (tire pressure has been fine the whole time). I had to rescan as it stopped reporting air pressure, then it would randomly work again, sometimes I would need an additional scan to work. Finally it's popped up with a have you changed your tyres question, I didn't think anything on it until it happened again. So far it's happened 4 times and the only way to get it to go away even if it's reporting the pressure is to have the sensor scanned again.
Stopped by the shop they scanned the sensors and it was indicated as ok (their scanner doesn't give any other info) and the car isn't throwing any codes currently.
Any suggestions of what might be going on?
