Hi All, Going to replace my front wheel bearings 99 Boxster Base. I planned on removing the wheel carrier and bringing off to a machine shop to get the old ones pressed out and new ones pressed in...only 40.00 a side. Is there a chance I will trash the balljoints during removal? Should I replace the control arms while I'm in there? Any tips or suggestions? Thanks V
Ok....The forked part of the tool should go under the rubber boot of the ball joint as to not rip the rubber....correct? Probably should not use a fork(pickle fork I think they call 'em) Thanks V
OK...I trashed both Tie rod end boot and wishbone boot as well so I'm going to just replace them. Seemed the ball joints were very easy to move around so I think they were shot anyway(someone agree with me!!!) Is it necessary to replace the hub bolt? Should I consider replacing anything else while I'm in there? Thanks V
Got 1 side completely done. Just a few things. Torquing the rearward bolt for the control arm was guesstimated ...I couldn't get in there w/ a torque wrench even with a crows foot. Dont have that torque extension tool you attach to a wrench. I got it on real tight comparable to wheel lug tightness(calls for 118 Ft Lbs) Next is the axle bolt....340 Ft Lbs ....really? Gona stand on a breaker bar at 19 inches ( I weight 208) What say all? V
