I'm having intermittent screen problem with the screen on my original na  radio cd head unit.  The screen is is grey with a couple lines but every now and then the proper screen pops up.  All the features work.
Is there a reasonable repair or replacement or is it time to replace head or entire system?
  • 5 months later...
  On 5/2/2021 at 8:48 PM, Porschelibrarian said:
I have the Bose Nav double din system.  Would it be mostly a remove old unit and install new or aprox what will it entail to install PCCM+?
Expand
If you have a MOST system it’s basically plug and play. On the other hand, non MOST system are problematic.
