Can anyone explain how to clear the ant-drive off mode for a 97 986?? CLU got wet, Soaked it in alcohol and dried. Seems to have helped but now when I go to start the car it won't start. Fault code indicates it's in a anti-drive off mode, if I clear the fault it allows me to start the engine, if I leave the key in I can start it several times. Once I remove the key it goes back into the ant-drive off mode. Any and all info would greatly be appreciated, Thanks
  • 4 weeks later...
Hi
What a PITA. I would try drying it out even more. Or even getting it repaired. It must be cheaper than replacing the whole triumvirate of the CLU/DME/Keyfob.
Best of luck
Berni
