I'm about to do the finishing part of the Cruise Control retrofit and so need to get to PIN A38 on the DME connector
Does anyone know the best way to open the DME connector to allow access to the pins? How do you open it without breaking anything?
Also How do you get pins out of the connector block?
UPDATE:
so it’s easier to actually goto the relay carier Blue Block PIN3
done this and coded with PIWIS - all good and working
thanks everyone
