Hi, one of the side latches on the soft top clamshell is stuck in the locked position. I’m pretty sure the connecting rod has dropped off the hook. The emergency crank handle doesn’t seem to operate the side hooks and it’s impossible to get access to refit the connecting rod unless the clamshell is open.
Any ideas as to how I can gain access to it or if it is possible to manually move the hook to the open position. I’ve tried to wiggle my hand up beneath the clamshell but it needs a contortionist’s hand.
