There are tons of power outlets in this car, does anyone know which one of these turn off when the car turns off? All the ones I try stay powered on when the car is off and draw power with my bluetooth adapter plugged in. I tried the front outlet by the radio, the two under the passenger dash area, the one in the back seat behind front center console and the two on each side of the trunk.
Thanks in advance.
All 12V outlets have power when the car is turn off on my 2005 Cayenne S.  When I setup my V1 15 years ago, I use the fuse power from the right side fuse box for the air suspension.  Last year, I added and used the the same connection for my dash cam as well.
