Good evening everyone. I've been chasing an intermittent short in the ignition/fuel injection (fuse C2) circuit. It's left me stranded a few times and I believe I've exhausted the most common issues. Would anyone be able to share wiring diagrams for the ignition, fuel injection, DME systems?
Here are the things I've eliminated already:
-Replaced ignition switch
-Replaced all relays in both relay panels
-Unplugged all four O2 Sensors = C2 fuse still shorts
-Unplugged both Camshift solenoids = C2 fuse still shorts
-Unplugged DME/ECU = C2 fuse still shorts
-Unplugged Immobilizer under driver seat = C2 fuse still shorts
I thought this intermittent short was fixed six months ago when I replaced the engine but now the 30amp fuse either blows as soon as I put it in the panel without the ignition on or blows as soon as I turn the key on. I think I can figure this out with some good wiring diagrams.
Jethro
I have a similar issue - no power at all to fuse A5  - so far replaced the entire rear loom - now stripping out the front one to replace - so many wires....
