Can anyone shed light on these two DTCs which I pulled up on my Durametric?  The durametric does not describe them, just says "Warning Indicator Off, Test Completed this Monitoring Cycle, Test Failed Since last clear, test completed since last clear, pending DTC, test failed this operation cycle, fault active"
Any help greatly appreciated
  • 2 years later...
Were you able to identify what these two codes meant / the issue?  On our 2017 Porsche Cayenne S E-Hybrid, had the same two error codes get identified by independent mechanic, but were not able to clearly identify, they cleared them and did not return on test drive.
