I have been having an issue with my 2003 Boxster S. when the top folds down the top will not go all of the way down creating an issue where the Tonneau cover will not go all of the way down as it cannot compress the roof down enough. I have disconnected the arms to the top and tried to put the top down manually but even when it is disconnected it is binding. when i force the glass from the bottom is finally pushes into place and then the roof will sit flat and the tonneua cover will close all of the way. not sure if its a cable, lubrication, a broken arm or something else, there isn't anything that is obviously broken so I am lost..... HELP!
I have exactly the same issue 2003 also, if I lift the window just slightly a couple of inches it will finish closing. Can't figure out why its not falling into place correctly.
Did you resolve this? If so, how please.
