1 hour ago, rich59901 said:
Anyone have any experience with using CV Split Boots on a 03 986 and know of a source to get them? Good,Bad or Indefferent?
Welcome to RennTech:welcomeani:
Common Boxster problem, worse with the S model due to axle shaft angles.  Boot replacement is also a common, if messy, DIY project.
Yeah, I've read all about it. This one came from Hemet CA in the dry heat and didn't get driven for 4 years,,The CV joint is fine.Tight and no knocking..It's a pricey replacement just for a boot..I'm still searching for a split boot..
Didn’t use a split boot, that is asking from trouble; pull the axle and replace it with the correct part.
