I have replaced the expansion tank.  In  the process I did not drain the coolant from the block, but only from the tank and upper lines.  When I refill coolant this weekend can I bleed it manually?  Will it be an issue? Or do I need a mechanic with he proper coolant pump/bleeder system.  Thanks in advance.
1999 996 Carrera Cabriolet
Edited by bthielbar
