can any guru point out what cause the front passenger carpet wet ?i can't figure out why.i appreciate if someone can help .thank's :huh:
try my reply in the thread immediately below... "wet trunk"...your drain plugs might be clogged, but i haven't heard of it getting the passenger compartment wet
  • 2 months later...
The evaporator housing has a water drain for condensation which forms when hot air is blown across the evaporator. This is why you'll see a puddle of water under your car if you let it idle with the AC on in the same spot for a while. If the hose falls off, the floor on the passenger side will get drenched.
