Very scary thing happens to me this night. On the highway i hear a strange noise . Stopped the car .what I saw made me feel a bit scary . The turbo s with his bigger brakes has a mounted socket on the brake discs. It’s connected with a handful of special screws  some of the screws
Are destroyed and the socket is not fitted to the brake disc anymore. Unbelievable.
could somebody provide me with the part number of the screws . Thank you very much
Wow! If the hat separated from the disc because those fasteners were missing or came loose I fear that rotor may be ruined as the rotational forces while the wheel is in motion may have ovaled-out the mounting holes. Good luck and keep us posted.
It’s not completely separated because some fasteners are still in place  but 3 are missing / destroyed. I will try to post a picture.
Edited by ekstroemtj
These bolts are tightened to 270Nm or 200 ftlb, it's obvious that at some time they have been removed and put back NOT according to the service instructions. I would check the other side, let us know.
What model, 955 or 957?
Hi Rick. Sure somebody has touched the discs. . The car is a 2005 Cayenne Turbo S with 500 PS. These are not the original Discs anymore. I will get some new brake discs and report how the other side is going to look
