I have this ticking noise that increases and decreases with RPM. I was told its a failed cat, that the biscuit inside had become loose and is the cause of the tick. I installed new cats today on both sides and the ticking is still there. Ill try to get a video clip of it. But if anyone has expeirienced this please let me know. I got the car back from a reputable porsche specialist shop on tuesday and after an IMS, RMS, AOS, coils, plugs, engine mounts, and a couple other routine services the car was given a 100% clean bill of health.
You had a lot of work done on the car at one time.  One thing to check is to make sure all the spark plugs are tight.  Any CEL?
I agree with DBJoe996. I changed my plugs and coils and a day later had a ticking sound with no performance impact. I never would have expected a loose plug. However, I got back under the car and checked each plug in the bank and that turned out to be the problem.
Sent from my iPhone using Tapatalk
Yes, it was clear the plug was loose. Apparently, I had not torqued to spec. I got my torque wrench out and made sure I 22ft lbs of torque on the plugs.
Haven’t looked into it yet. I’ve had alot going on. I will for sure let you know when I figure it out though.
