Passenger side door window will not drop when door is opened.
Passenger side door window will go up when door is closed
I removed the outside door handle micro switch.
It has continuity when the plunger is pressed.
It reads 4.7 Ohms when the plunger is pressed
Regulator was replaced in 2016
Anything else I should be looking at?
