My 2006 cayenne S, has been loosing suspension pressure on the front, this happened for two days, once the car switches on they seem to get back to their normal ride height and drives fine with no errors in the dash. This kept happening for two days. Last evening I put the suspension on its top most rude height, lowered it, later drove
It around and parked. This morning when I checked the suspension seems fine and front suspension hasn’t gone down. Can someone tell what can cause this crazy issue and if something needs to be checked.
Sent from my iPhone using Tapatalk
A scan with a Porsche dedicated tool like Durametric or PIWIS should be able to identify the culprit straight away
A simple visual check may help as well, i.e., when you come out to the truck which end and side seems lower than the rest?
