Morning people , yet another question.
Going to fit an analogue clock into the factory dash enclosure designed for the compass / stopwatch etc. So before i purchase the dash panel i need to find out what size the hole is that accepts the gauge so i can order one that is the correct size. They seem to be available from Speedhut in either 2" or 2 5/8" sizes.
So if anyone knows the size of the hole in the panel or the outside diameter of a genuine gauge it would be good to know.
I dont want a genuine one as the hands seem to fall off , no point in  having a compass or a stopwatch for the daily driving that i do.
Thanks in advance.
I'm pretty sure the 2" opening will be too small. Here are two pictures taken from the front, but without removing the panel, I can't verify. Let me know if you need me to do that.
  • Like 1
That is perfect , many thanks.
As you said the 2" one will be too small meaning i would need to make an adaptor spacer to take up the difference , the 2 5/8" (67mm) looks like it will be too large to fit into the bezel so i can rule that out as i am not butchering a new (expensive) panel.
Thanks again.
Regards - Kenny
  • Like 1
  • 4 weeks later...
Finally got the modification complete , couldn`t bring myself to part with almost £600 for just the clock then having to faff around wiring it into the car so i purchased a genuine panel for £100 + vat then got myself a 52mm clock from a company called R-Spec as it matched the rest of the dash (black / white /orange pointers) and made myself a stepped stainless steel bush to fit it to the panel.
Not full factory spec but to the untrained eye it looks ok , plus the hands shouldn`t fall off :thumbup:
50104105981_758a8777ab_k.jpg20200712_075501 by Kenny Niven, on Flickr
Kenny
Edited by Kendo30
