Hi
I just got my litronics install yesterday night loved it.
I connected all the wire except the red/blk wire that suppose to me tapped to the brown/red wire, is this for the headlight washer?
I didn't connect it because I don't have the washer for my lights and the lights work fine.
Will it be ok?
That wire is to get you 12 volts to the control unit. If you do not hook it up the lights will work fine, but I do not think the low beam will rotate up when you switch to high beam.
