If your original know is from the Exclusive options then it has a set screw up under the boot near the knob. If it is a standard knob then you just twist and pull - you might want to lower the top as sometimes they pop right off when pulled. The new knob likely has a set screw to fasten it down.
You have to unsnap the boot at the bottom. It basically just pops out (pull up on the edges). Then you have access to the set screw, which needs to be loosened. Some shifters don't have a set screw.
Once the set screw is loose, you basically just pull really hard on the shifter as it is largely held on with friction. Make sure you don't hurt yourself when it suddenly comes loose (i.e. don't pull toward your face).
