02 C2
I pulled:
P0300
p0301
P0306
Random multiple cylinder misfire
Cylinder 1 misfire
Cylinder 6 misfire
Also, not sure if its related but I have a very light oil leak. Its a few drops over a couple of weeks that has accumulated to about a 6”x6” spot. I havent driven the car in over a month and last time I did it drove perfect. I was going to finally take it out and I got about 2 blocks before the CEL came on. So I drove it back to the garage and pulled the codes. I didnt feel any loss of power or vibrations that a multiple cylinder misfire would create.
8 minutes ago, Eștii said:
02 C2
I pulled:
P0300
p0301
P0306
Cylinder 1 misfire
Cylinder 6 misfire
Oil leaks and misfires are often the result of the oil getting to the coil packs and/or plugs.  You need to get the car up in the air, find the leak and fix it.  I would then pull at least cylinders 1 and 6 coil packs and plugs and have a good look at them.  If the packs are cracked, you may be in the market for some new coils.
Good luck.
Agree totally with JFP.  Coil  packs and plugs are where to start.  Check them out.  Also, not having driven in over a month means perhaps your tank of gas is old.  Might not be the problem but adding some Techron to the tank, and a full fresh tank of gas wouldn't hurt.  Plan on changing the oil after that tank has run through.
