Note:  I call ‘back of the door’ the part of the door that is facing backwards, not the back portion of the door panel
On the back of the door there are 2 black ‘bolts’ that secure the lock to the door.  They seem to be designed for a Torx bit, but none of my Torx bits seem to fit properly.  What is the correct tool for removing those bolts and where can it be purchased?
Most likely triple square (AKA XZN) bolts.  I used Snap-on, but a lot of other tool companies make them as well.  Amazon also sells them.
Renekton Triple Square Spline Bit Socket Set XZN,Tamper Proof,1/2" 3/8" 1/4" Drive,M4 - M18,S2 Steel,10 Pieces
That's the name of what I bought
Sent from my GM1917 using Tapatalk
I can confirm that all of the above is correct...triple square XZN bit.  Do not try to use a torx bit in there because it will tear it up.
13 minutes ago, Philip54 said:
Thanks to All.
Is there a specific torque to put the bolts back?.  Is Loctite require?
20 +/- 2 Nm, or 15 +/- 1.5 ft. lbs.  Loctite is optional, but use med strength if you do.
