I have a 2003 cayenne turbo and suddenly have been having issues with the drivers side door locking mechanism. I have no errors when checking with durametric. My problem is that when I open the door, the lock actuator gets stuck at the first click and I am not able to close to door because it hits the metal lock and I have to use my finger to pull it back into its starting position while either pulling on the inner or outer door handle. When the door is closed, I am able to open to door with the inner or outer handle but cannot close it because of this issue. I went through the steps. I tried the fix as noted in the link below about adjusting the locking mechanism but it made no difference. When it push the lock through both clicks, the outer and inner handles will not pop it back into its starting position and I have to do it manual will pulling on of the handles.
https://rennlist.com/forums/cayenne-diy/1069169-955-957-cayenne-diy-door-handle-s-inoperable-fix.html
Could it be an electrical issue with the actuator and not mechanical since the handle will open the door?
