Hi ,
I have the following fault on the car I’ve had the codes read and the right hand control unit isn’t communicating.
Ive swapped the headlights over and the right hand can be read when connected into the left but the left can not be read when connected into the right so I can only assume there’s a break in the communication connection somewhere .
I’m assuming the purple and brown are the communication cables is there a way to test these cables ie voltage etc and where do the run to I had hoped they might be looped between headlights but it appears not ?
