Turned AC on for the first time this spring.  Water gradually started leaking on/to passenger side carpet.  It had rained too, so I originally thought it was rain water leaking in, bit when o got home, I used a hose on the windshield to see if further leaking happened.  It didn’t, with ac on, I felt around under the carpet and behind the center panel and felt cold water dripping.  When I turned the ac off, the dripping stopped.  I think it’s a blockage in the ac condensate valve or line.  Am I correct? If yes, can I fix it myself, or do I need to hit the Porsche dealer???
Expand
It is the AC condensate line back up, which should exit under the car.  There are many DIY fixes for this online.
