Hi everyone! I have a '99 911 996 c2. I just did an overhaul replacing the IMS, clutch, and much more. Got everything put back together and car wont start. When I bypass the ignition by using a wire to touch the starter solenoid to ground cable, it starts right up and drives fine. Any advice?
What?  You are using a wire to ground the starter solenoid and it works to start the motor?  Something seems wrong with that.  The starter is grounded by virtue that it is bolted to the engine block, which is grounded by a wire near the rear passenger wheel well. There is no separate ground for the solenoid to starter because the solenoid is bolted to the starter.  Sorry, something here doesn't make sense.
