I've read various posts on this topic and this tutorial but I'm still not clear on which item to look at first.
Current situation is no beep when locked by keyfob and double beep when unlocked.  Locking & unlocking from the key cylinder seems to be have normally (one time unlocking set off the alarm but that was not consistent behavior).  Opening from the outer passenger handle there is no window drop down.  Opening from inner passenger handle there is no window drop down.  This is the first time in a year that I've had consistent symptoms,  previously it would happen sporadically but when I sit down to try different combinations it would start working again preventing me from further diagnosing.
Durametric scan attached
Ideas?
Besides all  the other microswitches external and internal to the door latch mechanism, there is one microswitch that sits on the top of the door handle hinge that signals when the door handle is pulled.  You have to pull the door card off to get to it.  Some pretty good information here
RENNLIST.COM
996 Forum - DIY: 996 Door Latch Replacement [Detailed] - If your window does not stay lowered when your door is open, chances are that a switch within the door latch has gone out. This is a detailed procedure to change...
