WOrked fine yesterday warm day today Press Snowflake button and it did not illuminate on display panel and no blower fan. Checked fuses and relay all ok. Any ideas? Cheers
How do you know the AC relay is working?  Did you take it out and test it?  Suggestion - check all the fuses.  There are several for AC and climate control system.  Look at your fuse diagram inside the fuse panel.  What happens if you put the climate control system on Auto and run the temp all the way down?
