After about 10 to  15min of driving the front air suspension deflated completely and the Red suspension faulty warning light is present on the dash, In the morning when I start the car the front suspension will rise to the correct level only to fail again after the same time period.
any help will be appreciated.
Alan
Leaky valve block or air spring. You should get to a good independent with the proper scan tools to see where the fault is so it can be corrected
