How to bleed PDCC - looking for information or a link
Hi, I'm in Australia, so not looking for physical help but does anyone know the procedure for bleeding the PDCC. I blew a hose and have repaired it but now the system is dry. I do have a Durametric but it doesn't have the bleed feature.
Sorry, you will need a PIWIS tester to do this.
Select the Cayenne PDCC menu item and work through the following points in sequence. Follow the instructions on the PIWIS Tester:
Drive links >> Valve timing.
Drive links >> Bleed. > 430307 Bleeding Porsche Dynamic Chassis Control (PDCC)
Drive links >> Perform system test.
Read out and erase fault memory.
Perform a test drive.
Read out the fault memory again.
Do you mean it can't be done at all without the PIWIS ?
Edited by Guest
