Hey guys I have a 99 996 cabriolet that is in need of a new lid motor.  I have removed old motor that had part # 996.624.122.00, apparently this motor has been superseded by a new motor part # 996-561-933-01.  My question is, is this new motor needs a support bracket, new micro switch with alternate mounting holes and 4 studs.  I got the micro switch bracket mounted but cannot figure out how the support bracket and studs work with mount the new motor to gear drive.  Has anyone replaced the motor with this new setup?  If so can you tell me how it all mounts together?  I am stumped as the new support bracket has now where to mount with my current stock setup.  Thanks for any help you can give me.
Hallo Mr. Goode ... I replaced  a few .. just did my 2003 996 ...send some pics..there is 2 variations ...
I can show you mine , Im taking it apart 1/2-way to repair some fabric & rubber
