Slight twist on the standard window doesn’t drop when opening the door problem, and I could use your help.
When I stick my hand in to the area near the door handle and wiggle the wires, the window will drop the proper amount but immediately roll back up, over and over as long as I have hold of the wires.
When I put the door panel back on and button everything up, the window stops dropping.
You have either a short in the wiring or a bad microswitch on the door handle, or just a bad connection to the microswitch. Clean up all connections with electrical contact cleaner.
