My 986 has had both a new MAF sensor and an oil separator fitted recently but still runs rough, stalls, no throttle response at some stages and then perfectly OK at others??, when I disconnect the MAF wires it seems to run very well, any ideas??, will it do any damage if I continue to run it with the MAF wires disconnected? Thanks Paul
Are you sure the MAF is the right one for your engine? See the table at the end of this page. There even may be updates from when that was put together but it will give you an idea of the breakpoints for the various parts.
