I am getting  CELs P300, P304, P305, P306 in my 2003 3.6L 996 and the motor will only accelerate slowly. After reading a number of old posts on this forum I suspect a problem with the cam solenoid on bank 2. On the bench it shows 10.6 ohms across the terminals and no shorts to the cover. When 12V is applied it clicks but the inner slide only shifts outward about 3mm. The inner spring is at least 10 mm long so I am wondering if it is exhibiting full movement. It isn't gummed up and nothing appears to be blocking the inner slider.
Does anyone know how much movement to expect?
thanks,
Keith in Denver
