Well ....spring is coming and I will probably start chasing my P1123/P1125 CEL codes. They spring up every so often....so far i drove 100 miles without the CEL but it is pending. 99 Boxster....new MAF/AOS Gas Cap/Oil o ring/cleaned Throttle body. Can I use one of those water based DJ smoke machines to find a vacuum leak. Or should I just buy a fuel press.regulator which is a little more than the smoke machine. Regulator pulled about 15'' of vacuum which is on the low side I believe. Fuel pressure 3.3 bar engine off and 3.1 bar engine idling. Where should i start. Thanks V
