Hi All, Adding the Litronic control module to my litronic upgrade (99 boxster) and don't want to spend 125.00 on a wire harness.(The only thing cheap about a porsche is the owner!!!) No luck finding a used harness or pigtail. So.....I was thinking of making my own harness using the correct crimp on pins that are available. I need to get a pinout for the module. I can make out that 4 wires for each side that go to the headlights(8 total) there are 9 other wires(sounds like too many to me) that are the mystery. If anyone has more info that would be great. Thanks V
