2 hours ago, Mike Smyklo said:
Hello -
Had some work done and now also in need of my radio code. Thanks in advance for any help that can be provided!
I have a 2002 996 Carrera 4S
It is a CR-220
Becker 1
Serial Number: 15003323
Try 2767
Hi I have a 2001 996
It has the CDR 220
serial (update this is the wrong number… will look up again and update!)
registered as a 2001 but serial says 09/2000
I've been through two batteries and never gotten this radio to work! Any help would be great Appreciated.
Edited by MCalbear
It has the CDR 220
serial s620746
Try 2626
3 hours ago, MikeBerlin said:
Hi at all! For my fathers car I need the code from the cdr-22. He lost the code and after the battery went down it stops working without code.
Type 4467
Serial Y5024776
24/99
Thank you!
Try 9025
1 hour ago, StuGor said:
I need the radio and sat nav codes for a Becker Idis PCM1
Serial numbers
Becker - BE2580 Y5034690
Siemens - PO8030075456/03
From the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
