7 minutes ago, Cptn Bob said:
I need a code for radio reset after replacing the battery
have a 2000 Boxster S with a
Becker CDR 220 with CD player 4462
Serial no 15064818
Appreciate your reply
Cptn Bob
Try 2946
On 4/1/2024 at 11:36 AM, Loren said:
Try 9593
That worked! Thanks again! You are doing the lords work here !
4 hours ago, Linden Meuser said:
Hoping someone can help me find the correct code for this unit.
Thanks in advance,
Linden
Try 4692
May I please get a code for my Porsche Boxster 2000 Radio
details:
model BE-4462
S/N X5031767
Thank you kindly
Highnrg2
Edited by Loren
Removed VIN
details:
model BE-4462
S/N X5031767
Thank you kindly
Highnrg2
Try 2604
I recently purchased a 986 as my first Porsche and did not have the radio code supplied.
May I please have a code for:
Porsche CDR 22
986
type 4467
seri x5021541
Any help would be greatly appreciated.
Edited by MaxLeicester
Wrong serial number
Porsche CDR 22
986
type 4467
seri x5021541
Try 1043
Loren;
Just got another P-Car.
Code is lost with previous owner.
CR-220 Becker 1
Type 4362
Serial # Y5023366
Respectfully;
Don Steiner
6 hours ago, Don Steiner said:
Loren;
CR-220 Becker 1
Type 4362
Serial # Y5023366
Respectfully;
Don Steiner
Try 7695
I can not fine the code for my Becker CDR-220 Type 4462 SN X5028070.  If possible, will please tell me the code for it?
Toby
99 Boxster 968
Toby
99 Boxster 968
Try 5145
I have a 1999 996 with a Siemens & Becker - PCM (Porsche Communication Management) . It has missing pixels and I want to change out the unit. I have located another unit, and it has the serial numbers on the unit but it sounds like I cannot swap them without the VIN of the donor unit? Is that correct?
No, the new PCM just has to be coded to your car. Usually this is done with a PIWIS. I do not know if Durametric can do this.
4 minutes ago, Andrew Dyer said:
Hello, Can you find the code for my 00’ Boxster. The model is a cdr220. The serial number is: X1040081
thanks!
Try 4232
Just now, Andrew Dyer said:
That one didn’t seem to work
From the Lost Radio Code FAQ... that I am sure you read...
"The suggested number did not work - what do I do now?
Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work."
I am so sorry. The serial number is X5029787
