14 minutes ago, Matt Fussell said:
This thread is awesome! I need some help with my radio. The model is BE 2582. Serial number Y5007985.
From the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
9 hours ago, Nick Chesshir said:
Hello,
Just got my wife a 04 Cayenne S and needs a radio code and had no manuals.
Typ: CDR-23
Model No: BE 6627
Serial No: 35005451
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
When we power on the radio it says protect and allows us to click the bottom buttons to enter a code.
But if they talk over the fiber bus it seems something isn’t working being there is a fiber signal out of the stereo but not into the stereo.
I guess it’ll be time to retire it and get something more modern.
thanks for the help
Hi there!
Recently bought a 2000 Porsche Boxster S without any manual and need the radio code.
CDR-220
Serial # - X5032962
Type: 4462
48/98
If you need anymore information, let me know! Thanks again!
thanks for the help
"CDR-23 (or later):
41 minutes ago, Ishandhawan said:
Hi there!
CDR-220
Serial # - X5032962
Type: 4462
48/98
Try 4727
8 hours ago, Dana_k said:
Good morning. Could please anyone help me with the code of a Becker radio?
model BE 7045
Serial No : 78039394
thank you !
That is not a Porsche radio - so this may not work.
Try 9618
On 2/7/2021 at 7:27 AM, Loren said:
Try 3542
Hi Loren, Could you please look up my radio code? I just replaced the battery and it locked up.
2003 Porsche 996 Carrera 4S
CR-2200
Type 4467
Serial 15003175
Edited by 8350135洪機
CR-2200
Type 4467
Serial 15003175
Try 5414
1 hour ago, Not_James said:
Good evening, just revived from a dead battery in my 996.
CDR-220
Serial # - Y5022282
Type: 4362
24/99
Thank you!
Try 2629
7 hours ago, Anandan Subramaniam said:
Hi Can you help provide code for
Model number BE 2580
Serial number 65151489
From the Lost Radio FAQ...
Hello I need some help in finding my radio code .
2002 Carrera C2
CDR-220 model BE-4462
serial no X5026285
Thanks so much!
2002 Carrera C2
serial no X5026285
Thanks so much!
Try 9812
  • Thanks 1
