5 hours ago, Martinanddee Clarke said:
Hi Lost radio code,  Wrong number in the manual can anyone  help
"2000 Boxster S
Becker cassette Radio
Model 4367
Serial no X50 18079
Try 5217
7 minutes ago, Martinanddee Clarke said:
Lost radio code, any help would be appreciated
986 Porsche Boxster s
Becker cassette  radio model 4367 serial no x5018079
I already answered your request here...
13 minutes ago, Julian Hibbert said:
Hi radio nor working after flat battery asking for code. Radio is CDR - 22
TYPE 4467
SERI 25008451
24/99
Any help much appreciated.
Try 7543
3 hours ago, TNT79Bronco said:
Could use some help with my radio code.
Becker 1
Serial # 15001317
Type 4352
Thank you very much.
Try 7683
Hello Porsche friends,
I need the radio code for a 2001 Boxster I just bought for my son.
CDR 220
Type 4462
CDP 2081
24/99
serial 15076106
thanks,
Bill
CDR 220
Type 4462
CDP 2081
24/99
serial 15076106
thanks,
Bill
Try 9397
1998 Porsche Boxster
Bought car a year ago and haven’t been able to get the radio working since because of this radio code issue. We have tried 1209 based on what one service tech told us but it doesn’t work. Hoping you can help! Thanks!
becker
cr210
serial number: V5007001
becker
cr210
Try 2109
3 hours ago, RyanCharlie said:
Thank you but 2109 didn’t work
any other thoughts?
Did you use the procedure in the Lost Radio Code FAQ?
If not, then your radio may have been repaired and the serial number changed (electronically.
If you did use the procedure and the code I gave you does not work then it is likely that the radio was repaired by someone other than Becker - in that case I can not help you.
I read everything in the FAQ - but it just tells you how to get the serial # which I already had.  If there are steps to follow then I could not find that in the post.
I know the serial number is correct bc it comes up on the display following those steps and we also removed the unit and saw it on the back.
Hello guys,
My radio is a CR-220 Becker 1
Type: 4362
Serial: y5021061
Build Date: 47/98
Thank you so much in advance!
Hi All!  I have a Becker CD-2 from a 1992 964 C4 and I have lost the code.  Can anyone help?
Serial number:  A0614401
Thank you!
Robert Liberty
502.533.4996
2 hours ago, TJ said:
Hello guys,
Type: 4362
Serial: y5021061
Build Date: 47/98
Try 0298
Thank you!
Robert Liberty
502.533.4996
This is a radio not a CD player serial, right?
Not sure that's pretty old.
Try 7289
Try 7289
It is a CD player.  CD-2
Thank you very much!
