10 minutes ago, Loren said:
Did you follow the procedure in the Lost Radio Code FAQ?
Yes only thing i missed it that it’s cr220? And I just realized I typed serial number wrong!! So sorry! It’s actually W5007574.
Try 5272
5272 worked!! Thanks so much..happy to be a new member of a responsive community! And happy to donate to a great community. Thanks again
I removed the radio from my 996 and now the code is required, which I don't have. Could you please help?
I attach a picture of the radio serial sticker with all of the info on, but the details are also as follows:
Type: Becker CDR23
Model no: BE 6612
Serial no: 35046851
12 Volt EC: 123
Many thanks in advance!
Derek
IMG_1405.HEIC
27 minutes ago, Derek N said:
Type: Becker CDR23
Model no: BE 6612
Serial no: 35046851
12 Volt EC: 123
Derek
Sorry, you did not read the Lost Radio Code FAQ...
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
Please Help you're my only hope!
Fixing up a '97 Boxster I just got, got the stereo to turn on but of course it wants a code
Brand/Type: Becker CDR 210
Model-No: BE 2282
Serial Number: T5005054
Thanks in advance!
Model-No: BE 2282
Thanks in advance!
Try 6587
2 hours ago, GGGG 1997 Box said:
Good evening.  I have a Becker/Porsche CR210 Model BE2182 serial No. v5004327 and need a radio code.  Thank you in advance
Try 3213
Hi there,
Can someone please help. I have a cr-210 with the serial # W502477.
Thanks in advance for the assistance!
Hi guys. I just purchased a porsche boxster with a cr-220 radio
The serial number is 15031875
The model number is be 4362
Can anyone helo me find the code for this radio?
Thanks alot
10 hours ago, rexg said:
Hi there,
Try 4942
Thanks alot
Try 0637
On 1/17/2022 at 11:25 PM, Loren said:
Try 4942
Just realized I put in the wrong serial number.. my bad..
The correct serial number is W5024774.
Again, thank you so much for doing this!
Try 9109
4 hours ago, Max Fixxer said:
Hi magic man 🙂
Can I also get a code for my cr-220 please!
Model-No: BE 4362
Serial Number: x5020545
Try 0265
Hello, i have a pcm and need a code to open it again. All the info i could find on the radio was:
Pcm in 99 C2
MLFB:5WK78000A
Serialno: PO8000040217/07
Date: 99041220
SW3.67
tell me if you need anything else!
i will for sure give a donation if you can help me!😊
Pcm in 99 C2
MLFB:5WK78000A
Date: 99041220
SW3.67
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
I’ve got 2 cars for which I seem to be missing the radio codes and would really appreciate any available help.
Car 1 is a 99 Boxster, serial number X5023019
Car 2 is a 99 Carrera, serial number X5018434
Thanks very much in advance,
Ian
