2 hours ago, abryxi said:
Hi Loren,
I need a radio code for me 2002 Porsche 996 Turbo.
CR 220
Serial 15031226
Type 4362
Thank you.
Ales
Try 2371
28 minutes ago, George82- said:
That didn’t work…. Anything else I can try?
Did you follow the procedure to get the correct serial number on the display?
If the unit has ever been repaired then the serial number on the radio (label) is likely wrong.
1 hour ago, liliechen said:
Hi Loren,
Please help with my 1998 Boxster CR210 radio code
serial: W5019082
model: BW2282
Thank you!
Try 1971
  • Like 1
Yes, this is the serial number from the display, it does match the label too..
Then chances are the radio was repaired by a third party (not Becker AutoSound) - and they did not set the serial number.
There is no way to know the serial number or the code unless Becker can fix it. Sorry...
5 hours ago, ramairws601 said:
Hello all! I have a Becker CR-210 that I need the unlock code for.
Model: BE216
SN: 55000911
Any help is greatly appreciated!
Try 4709
Hi Loren, I recently got locked out of my radio after disconnecting my battery. I've tried tracking it down via multiple dealerships but had no luck.
Model: CDR-220
Serial #: X5025897
Thanks for your time in advance!
Adam
Model: CDR-220
Serial #: X5025897
Adam
Try 6972
Hi there! Hoping someone is still able to help here. Thanks in advance for helping out the unlucky folks with no codes!
I have a 1999 Carerra 4
serial code: w5007584
Type: 4362
30/98
Type: 4362
30/98
Try 5352
