2 hours ago, Francesco Macri said:
Hello!
anyone have a radio code for
Becker 1
cdr-220
type 4462
# Y5044723
24/99
Try 5017
1 hour ago, Mark Castronovo said:
I also need a radio code after cleaning battery terminals.
Becker CDR220
Serial X5033383
Model BE 4462
Try 6831
I have a new battery in Porsche and cannot find the original code.  Can you help me out?
Radio Model # CDR220
Type 4462
Serial # X5017663
Type 4462
Serial # X5017663
Try 9568
I just purchased a 1997 Boxster and of course the previous owner didn't supply a radio code! Could you please help?
CR-210
BE2182
V5005586
Thank You
Randy
CR-210
BE2182
V5005586
Thank You
Randy
Try 9432
I took the battery out for the winter. When I looked for the code printed on my card, it had faded away. 😞
Radio Model # Becker CDR220
Type 4362
Serial # Y5023595
Type 4362
Serial # Y5023595
Try 1095
5 minutes ago, France Lacroix said:
radio code  for be2582 whit gps only one code !!!  serie 15009209 for my 996 2000 millenium 547/911 lost code
Thank
You didn't read the Lost Radio Code FAQ
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Hi, I have 2004 Porsche Cayenne 3.2, my radio stop working, so I order a used radio, I hook the radio up and no screen, how do you get it to work, the model number is BE 6636, Serial number is 35014765, Thanks.
Ok, Thanks, I think the radio should come on to be able to put a code in the radio ??????, the old radio light up for 3 seconds, then blackout, I get nothing on the replacment radio ?????
Edited by Frank Leonard
