3 hours ago, Justin Ludwig said:
Hello looking to see if I could get someone to look up my radio code, just changed my battery and it locked
1999 Porsche 911
CDR-220
type 4462
serial x5028912
Try 3542
I am trying to restore my OEM radio to my 1990 964, but apparently it is locked and I need a code to unlock it.
I have a CD2 for my 1990 964, which appears to be a refurbished unit.
SN: PO CD-2 A06 14468
Thanks so much in advance.
Scott
Scott
From the Lost Radio Code FAQ...
"Which radios fitted to Porsche can have their unlock code recovered through serial number?
- CR-220/CDR-220 - Becker
- CR-210/CDR-210 - Becker
- Traffic Pro NAV/CD - Becker
Which radios can not have their unlock code recovered through serial number?
- CR1 - Alpine
- CDR-23/24 (or later) - Becker
- PCM (Porsche Communication Management) – Siemens & Becker"
Vehicle 1998 Boxster (Sister's Car, now son's car)
VIN WP0CA2988WU624452
RADIO SER # WS019142
Model CDR210
Dead Battery, missing card, poor memory of my sister.
Thank you APJr. (08 997 Carrera S Cabriolet)
Model CDR210
Try 6035
That code worked on the 98 boxster, my son is very happy he will have tunes. thank you for the information and quick response
Hi Loren, Could you please look up my radio code? I just replaced the battery and it locked up.
2002 Porsche Boxster S
CDR-220
Type 4462
Serial 15006282
CDR-220
Type 4462
Serial 15006282
Try 8798
  • Thanks 1
2 hours ago, Daniel Lobron said:
Hi Team,
Could someone help me with the radio code for CDR-220 with serial number: Y5050543 (not sure if the 5s might be Ss instead?)
Thank you in advance!
Bonobo
Try 0249
Hope you can help with retrieving my radio code for a project I'm working on
2002 996 Cab
CDR-220
Becker 1
Type 9362
Serial X5016070
2002 996 Cab
CDR-220
Becker 1
Type 9362
Serial X5016070
Try 6525
2 minutes ago, JFL2021 said:
Loren
I tried the code and it didn’t work. My screen isn’t easily read.
might be type 4362
Radio codes are based off serial numbers.
If you gave me the correct serial number and the code I gave you does not work then it is likely that your radio has been repaired by someone other than Becker (the manufacturer). In that case I can not help you - Perhaps Becker can (for a price).
On 2/8/2021 at 9:28 AM, Loren said:
If you know the original radio vendor (Becker, Alpine, Blaupunkt, etc.) they might be able to help.
I believe it is an Alpine. I called my Porsche dealer in Boise, and they said they can unlock it if I drive the car to them,, 2.5 hours, each way..... Hoping for an easier alternative.
Hello from Brooklyn -
996 turbo  ‘01 - sealed up coolant lines and the radio is locked
Becker 1
Type: 4462
Serial: Y5041604
24/99
much appreciated, thank you for providing this service
Becker 1
Type: 4462
Serial: Y5041604
24/99
Try 4131
