1 hour ago, Forest Atkins said:
yep  replaced battery in 99 cab ….. can't find code in pile of documents provide by prior owner.
CDR 220     BE4462
Serial #   15075936
thanks in advance
Forest
Try 7284
Hello, I recently purchased a 96' Targa, the radio card was missing at sale and I was not aware until I just now went to operate the radio. Its a CR-210, serial number is S5000302. I called Porsche to see if they would look the code up for me, and the manager told me that Porsche no longer provides older radio codes?
I tired using a radio code website for which I paid and I have yet to receive a code. If you could help, it would be greatly appreciated.
Thanks in advance
Edit: I got my hands on the code, thanks anyways
Edited by Derrick Stankiewicz
Solved
Thanks in advance
Try 6753
Just like everyone else, I changed my battery and now I need a radio code. Any help is greatly appreciated.
The radio is a Becker cdr-220
Type 4462 48/98
Serial number x5033296
Thank you in advance.
Type 4462 48/98
Try 2651
  • Like 1
29 minutes ago, burns334 said:
Hi Loren, do I need a code for a cdr23? BE6612 S/n 25018297
Quote
CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
Hello!
I have a CD220/CDR220. Model is 4462. My Serial Number is: X5021737
I just purchased the vehicle. No code card with the owners manual.
I need to unplug the radio to address the raining foam insulation through the HVAC system
Many thanks in advance,
Kevin S.
10 hours ago, Kevin Shaffer said:
Hello!
Kevin S.
Try 2364
Hi Loren,
Juan, from Spain.
I am the proud owner of a Boxster 986 Manual shift MY97, and the other day I had a fantastic oportunity to buy another 986 tiptronic at a really nice price.
Could you be so kind to provide me with the radio code? I will do my best to do a nice restoration and keep another Boxster alive with his original radio.
Thanks very much in advance
radio code for CR-21
Model: BE 2180
serial number: T5000494
Edited by Juan Enrique Fullana
1 hour ago, Juan Enrique Fullana said:
Hi Loren,
Juan, from Spain.
Model: BE 2180
Try 9042
3 hours ago, chris campbell said:
Loren, it worked, thank you so much! How do you do this? Is this something I could help other Porsche owners with?
Magic  :wink:
1 hour ago, lostdavey said:
new battery on a fixer upper everything seems to work except the radio needs a code ,please radio magician
CDR 220
BE4462
Serial # y5042806
Try 2726
  • Like 1
