49 minutes ago, Fazit said:
Hi all!
I lost my radio code can anyone help me?
CR-220 Becker
4362 47/98
#y5020973
Try 9879
  • Thanks 1
The radio code in my manual was not working, and it turns out the radio has been replaced, and I do not have the new code.
CDR-220
Model: BE 6625
Serial: 15000207
2 hours ago, rwdragoon said:
I tried the dealer with the VIN but the code they supplied didn't work, can someone help please?
CR-220
4462
X5038207
Try 2154
CDR-220
Model: BE 6625
Serial: 15000207
Try 2409
Hi! Is it at all possible to work out the code for me? I picked up the car a few days ago, it had had the battery changed and the original card is not with the docs.
The info I can get from the display is...
BECKER 1
TYPE 4467
SERIAL 15037311
24/99
Thank you 🙏🏻
BECKER 1
TYPE 4467
SERIAL 15037311
24/99
Thank you 🙏🏻
Try 9830
  • Thanks 1
6 hours ago, Mark Benjamin Briscoe said:
Ok. Need help.  Rebuild is done.  Need code.
CDR-220
Model: 4462
Sreial: Y5051984
Thanks ahead of time.
Try 8687
  • Like 1
I hope someone can help with my code. I replaced my battery and now the radio is asking for a code. Here's my info:
BECKER
TYPE CDR23
SER: 25011313
36/02
Thanks very much in advance. : D
BECKER
TYPE CDR23
SER: 25011313
36/02
You did not read the Lost Radio Code FAQ...
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
On 6/25/2007 at 8:18 AM, toons92 said:
Thank you so much, I 'll try it the next week 🙂
I’ve tried a ton of these codes and none of them have worked on my 2000 Boxster S, is there a process for me to go through to find the right code?I’ve tried a ton of these codes and none of them have worked on my 2000 Boxster S, is there a process for me to go through to find the right code?
You need to read the Lost Radio Code FAQ...
Hi! Looking for some assistance with radio codes for a 996 if possible. Bought it from out of state and radio was locked upon delivery.
CDR-220
Type: 4462
Serial: W5012252
CDR-220
Type: 4462
Serial: W5012252
Try 2389
