On 5/14/2020 at 9:29 AM, Lou Bev said:
Still struggling with this and I can't get the code. I called my local dealer 3 times and they never return my call. If you can help please.
It is a Becker 1
Type 4462
Serial# 25017566
Does it help you if I add the vin#?
Thanks Loren but neither one worked, but to be clear, I should only have to enter the correct code one time right? There is not a need to enter it twice for confirmation?
Also, not sure if it helps but here is the vin# WP0AA29902S623012
Yes, then wait a couple of minutes.
I gave you two possible codes because part of your last S/N LED is out - so we are guessing.
6 hours ago, Christopher Cooper said:
Hi Loren,
I too am in need of a radio code:
99 911
CR-220
Becker 1
Type 4362
Serial: X5013242
Date?: 47/98
VIN: WP0AA2991XS625309
Thank you!
Try 8534
2 hours ago, Francisco Guillermo said:
Hi, first of all thanks for your help!
Typ: CDR 22
Model - No: BE 447
Serial - No: X5018872
Thanks again
Try 9537
Hi Loren,
My battery died and now I'm stuck with no music.
02 911 turbo
CDR 220
Model Nr. BE 6625
Serial Nr. 25011906
VIN: WP0AB29992S686543
Thank you in advance!
57 minutes ago, madeinsieradz said:
Hi Loren,
02 911 turbo
CDR 220
Model Nr. BE 6625
Serial Nr. 25011906
Try 0985
